Shows the Domain Name System (DNS) cache configuration (enabled or disabled) on a virtual router (VR) or VLAN.
| dns | Domain name system. |
| cache | Specifies showing the DNS cache information. |
| configuration | Specifies showing the DNS cache configuration (enabled or disabled). |
| vlan | Specifies showing the DNS cache configuration on a VLAN. |
| vlan_name | Specifies the VLAN name. |
| vr | Specifies showing the DNS configuration cache on a VR. |
| vr_name | Specifies the VR name. If not specified, the VR of the current command context is used. |
If no VR name is specified, the VR of the current command context is used.
None.
The following example shows the DNS cache configuration on VR "vrA":
# show dns cache configuration vrA DNS Cache : Enabled on some VLANs of virtual router "vrA" DNSSEC : Enabled VLAN DNS Cache Operational -------------------------------- --------- ----------- vlanA1 Enabled Up
This command was first available in ExtremeXOS 30.3.
Domain Name System Security Extension (DNSSEC) status was added in ExtremeXOS 31.1.
